Hi there!
Loving the Sophia template so far.
I do have a couple minor questions to do with the template on mobile devices. You'll need to log in.
Domain: missionsamburu.org
Login: removed
Password: removed
1. The login menu item on the footer menu is hanging off the right hand side of the page. This is true for mobile portrait and landscape, iPad portrait and landscape. But it's fine on the desktop. I cannot work out why this is?
2. On desktop, you can click on the parent menu items 'About' and 'Projects' and it will take you to a specific article, but on mobile, it will not let you click on them and go to the article. Is there any way around this?
3. The 'Get Involved' menu has no article associated with it, so it works fine on mobile. You can navigate to either sub-page from any page outside of 'Get Involved'. But once you are in one of the two sub-pages (Give or Pray), you can no longer go to the other page under the 'Get Involved' menu (ie you cannot go from Pray to Give). You have to navigate to a different page outside the menu, then back again. Do you have any idea why this might be?
Thanks for your help!
Tim
