I used the Sophia template. With an iPad, the menu does not switch to the "Mobile Menu" view. It doesn't matter whether the website is displayed in landscape or portrait format.
Can you help me here?
after I changed and saved the "Mobile Menu Breakpoint" a few times, the page on the iPad was displayed correctly. Now I have the problem that the menu bar is not displayed correctly. The icons are shown too far to the right. The attempt to change it via the CSS has unfortunately not yet worked. Can you help me with that?
.hornav .item-149 > ul {
left: auto;
right: 0;
Simply put, the 'Service' dropdown is pushing the wrapper outside of the viewport.
