1. bibbp
  4. Sunday, 11 September 2022
I need to add superscript TM (for trademark) to a work in a menu title. I see on the web there are various ways of doing this, can I do it using Sophia?
Many thanks
Peter
Hi Peter
Yes you should be able to simply paste the TM character in to the title field of your menu item settings. To copy this character may I suggest using your Windows Character Map application.
Yes of course! worked perfectly.
Many thanks, as always!
:D :D
