1. salinger
  4. Thursday, 20 February 2020
Hi Ciàran, I am using Novah template here http://www.maxwash.at/joomla/index.php
Inserted some links in the social media area but they do not appear.
Thank you , Marion
Hi Marion
one more issue to this template. I am trying to reduce space between menu list points.
I wrote this in custom css:
.hornav>ul>li {
margin: 0 7px;
but it did not work.
thanks, Marion
Hi Ciaran, the social media icons do appear, as soon as I placed a module to header2. So this issue is solved. Still the second is open.
Did you make any changes as the slider is boxed layout now and the news module is too big. looks like 1 colum but I have 3 colums,
thank you Marion
SOLVED, SORRY!!!!
... sorry one more issue... what happened to the side module (right side) ? the pics are all different sizes now?? the correct size is only in Mietfahrzeuge and Mietbagger. module size and pics size are all the same.
thanks, Marion
SOLVED, SORRY!!!!
Hi Marion
I am not sure if I understand you correctly. We hadn't made any changes to your Joomla installation. Looking at your homepage, there does not appear to be any modules published in the side column positions (eg. sidecol-1a).
Hi Ciaran, thank you , yes I commented my entries above as already solved, I thought you have made some changes, but of course it was my mistake, so sorry ;) so problems solved , Marion
Excellent... thank you for the update. :)
