1. ziggy
  4. Sunday, 28 October 2012
I have install the template and now the social button do not work i can not chage the url or turn them on or off.
Can someone help me
Hi bonami
If you wish you can send temporary administration access to your Joomla installation to [email protected] and we will examine the issue further.
Thank you.
There appears to be an issue with your server as we continually get the following error when navigating your Joomla administration...
Not Acceptable
An appropriate representation of the requested resource /administrator/index.php could not be found on this server.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
Do i have to change hosting or just re-install from scratch
  3. # 3
Have you been getting the same error when accessing your site via the frontend or administration area?
  3. # 4
yes i do get these messages when trying to save changes i am trying to make
  3. # 5
Ok.. just wanted to rule out any issue on my end preventing me making any changes.
In truth I'm not overly familiar with the issue as it is the fist time I have seen it. It has been suggested to disable 'Security Filtering' on your site by adding the following to your .htaccess
<IfModule mod_security.c>
SecFilterEngine Off
SecFilterScanPOST Off
</IfModule>
Failing that it may be worth disabling/uninstalling some of your extensions, removing them one by one. You may eventually find yourself reinstalling Joomla but this may be a good opportunity to find the source of the issue.
  3. # 6
I did a bit of investigating but not understand
Fixing 406 errors - general
This error occurs very infrequently in Web browsers, because most browsers will accept any data returned from the Web server.
If the client is not a Web browser, then anyone can only investigate the problem by looking at the Accept headers generated by the client system and the data stream returned by the Web server. If you do not have access to the source code for these systems, the only thing you can do is refer the problem to technical support people at the companies that developed the systems
http://www.checkupdown.com/status/E406.html
can you help me i re-install new filles still the same
  3. # 7
