1. erikoraka
  4. Monday, 24 April 2017
Regarding the two latest templates you are offering, LONDON and Kodaline, can you please tell me whether the Snipcart module you have integrated requires any programming knowledge on my side? Or is it configurable in a similar way as the other modules of Joomla51, ie Carousel etc?
Thank you in advance!
Eri
Hi Eri
Compared to most e-commerce solutions you will find this module relatively easy to use. Simply add your products to the module and SnipCart will take of the rest... https://snipcart.com/
Note: You will need to create a SnipCart account to use this module.
Thanks!
Can you also please tell me if I can download one of the aforementioned templates (ie LONDON) and just use the Snipcart module without altering the joomla51 SERENITY Template that I use right now for my website (http://www.gw-thegreekwineroutes.com)? Or the Snipcart module goes only with the LONDON template and I will have to switch my current template to the latter in order to be able to use the particular module?
Thank you again!
Eri
Hi Eri
Although It has not been tested, you should have no issues using the SnipCart module on other Joomla51 templates.
Hello again Ciaran,
I downloaded the Kodaline template but I cannot find the Snipcart module as I expected so, like for example the pricingtable module zip, in order to upload it to Serenity template I'm already using for my website. Should I expect to find it in the Kodaline zip folder I downloaded or is there another way to implement it?
Let me also tell you that I have already created an Account in Snipcart.com and I have the corresponding API key..
Can you please provide some basic guidelines on how to implement the snipcart module in my Serenity template? I thought that in the package that I downloaded for Kodaline I would find a zip named i.e. mod_j51snipcart.zip which I could upload to my site and use it accordingly. Am I right? Please advise..
Thank you in advance.
Kind regards,
Eri
Hi Eri
At present the SnipCart module is only available with our London template. Please find attached the module with this post.
Thanks a lot Ciaran!! :D
1. Regarding the snipcart, something is wrong when I set the number of columns for Mobile Landscape and Portrait: I think that the Mob Portrait Columns number follows the number set for the Mobile Landscape Columns..it seems that the field Columns (Mob Portrait) does not make any changes! The same happens with the desktop version: I change the tab version number of columns and the desktop version number of columns changes as well. In general I think something is wrong with the number of columns fields of the module!
2. Also, in the tab version of the module, when the Buy Now button is clicked, the cart window does not pop up!
Can you please advise?
3. Additionally, in the snipcart module how can I add a cart icon on the top right corner page, i.e like the one show in the attachment, so as to show the number of products the cart has in it?
In order to check, the url of the site is the following: http://www.gw-thegreekwineroutes.com/en/snipcart
Thank you in advance for your kind help!
Eri
Hi Eri.
1./2. May I suggest sending temporary administration access to your Joomla installation to info@joomla51.com and we will examine this issue further. For our reference please paste a link to this post in your email.
3. Sorry to say this option is not available with the Snipcart module.
Regarding 1 & 2 above, I followed what you suggested via e-mail:
"May I suggest adding your SnipCart module to a module position rather than within an article. This should resolve any responsive column issues."
...but the problem insists... I positioned the module in contentbottom-a but again the number of columns seems to "get confused" between desktop, mobile and tablet version!
Here's the link from the page with the snipcart: http://www.gw-thegreekwineroutes.com/en/snipcart
I have already sent you the credentials of my website at the joomla51 e-mail!
Thank you!
Best,
Eri
...Is there a possibility the problem to be the browser? I noticed (but I'm not sure...) that with Firefox the module works ok but with Safari not..!
And if that' s the case then can you please advice how to overcome it?
Hi Eri
We have updated your SnipCart module amending the mobile column issue.
Thank you Ciaran!
Could you also send me the mod_j51snipcart.zip with the amended files so as to be able to use it with Kodaline template I have downloaded, as well?
Thanks so much :)
Eri
Hi Eri
Please find attached the updated SnipCart module.
Regarding the snipcart's button I have two questions:
1. When I set the Button text to Book Now instead of Buy now it seems that it does not change! Can you please advise?
2. Can I use the 'Buy Now' button in a way so as when clicked, to lead to certain urls per product instead of opening the cart?
Kind regards,
Eri
Hi Eri
Is this for gw-thegreekwineroutes.com? If so you have already allowed us access and I will make the needed changes. Note you will need to amend the issue of us been unable to amend your template.
Yes, the site is the gw-thegreekwineroutes.com but I do not understand what the problem is as the credentials I have given you is the ones I am logging in the site too.
Can you please retry and inform me accordingly in order to find an alternative way if the problem insists?
Hi Eri
We have created an override for your module allowing you to use the Weight field to enter a URL for the SnipCart item button.
Thank you for your reply Ciaran but:
1. regarding the label of the button does not change to Book Now and
2. although I have filled in the field Weight with a URL the button does not work
http://www.gw-thegreekwineroutes.com/en/online-shop/
Hi Eri
1. The button text appears to match that of the corresponding module settings field (Book Now).
2. Your buttons should be now linking correctly.
  • 2
