1. erikoraka
  4. Tuesday, 22 February 2022
I use j51 snipcart module in the following pages of my website:
1. https://www.gw-wineroutes.com/en/wine-experiences
2. https://www.gw-wineroutes.com/en/wine-cruises-palette
When I click the button Details is it possible not for a new window to open but redirect to the url on the already opened page as it leads to pages within the site?
On the contrary on the snipcart used in the following url https://www.gw-wineroutes.com/en/winesouvenirs everything is ok as when I click the button I am redirected to Etsy on a new window which is what I want in this case as Etsy is a different website than mine.
Any css I could add?
Thank you in advance for your help!
Best regards,
Eri
Hi Eri
To amend try creating an override for your J51 Snip module, locate target="_blank" property on the a tag within and either remove or change to target="_self".
Thank you for your reply!
I was trying though to find where exactly to make the change you suggest and I couldn't.
Can you please help me find the exact place to the change the target of the module?
Thank you again for your help.
Kind regards,
Eri
Hi Eri
I have created an override for you. The default override layout will open items in the same window. The second override layout titled newwindow will open the item in a new window. The layout can be selected from the Advanced tab of your module settings.
It seems that both versions (default and newwindow) open in same window...
For example, in the following url https://www.gw-wineroutes.com/en/winesouvenirs I have set the newwindow version of the module but when I click the Buy now button it stills open in same window...
Can you please check it out?
Thanks again!
Eri
HI Eri
Your site appears to be currently running very slow and is continually timing out. We will try again later.
