This issue should be now resolve.
The following was replaced in your templates index.php (../templates/[YourTemplate]/index.php)...
<!-- Vegas Background Slideshow -->
(function($) {"use strict";
$(document).ready(function() {
$('#vegas-slideshow').vegas({
delay: <?php echo $headerslideinterval ?>,
timer: false,
slides: [
<?php
if(is_array($header_json['header_slide_image'])) {
foreach($header_json['header_slide_image'] as $value) {
{ src: '<?php echo $this->baseurl ?>/<?php echo $value; ?>'},
<?php } } ?>
})(jQuery);
</script>
With...
<?php if (!empty($headerslideshow)) { ?>
timer: false,
slides: [
<?php
<?php } } ?>
})(jQuery);
</script>
<?php } ?>
