Message
OSM_INVALID_SUBSCRIPTION_PLAN
  1. janneke
  3. Monday, 13 October 2014
I have a couple of images I want to run on the slideshow. Problem is that the slideshow shows almost every image, except the ones I want to show. The images (jpg) I want to show are 926 x 300. I tried smaller settings, bigger, 100%, with no result. When I place them in a map with other images in different sizes (joomla headers or other), all pictures show exept the right ones. What to do?
May I suggest the following article on troubleshooting the slideshow module... http://www.joomla51.com/tutorials/item/troubleshooting-the-slideshow
Hello Ciarán,
Thanks for your suggestion but I think there is some other problem...
1 - I run my site on Joomla3.3, so the jquery should be enabled. I did not eneble it in the slide-module.
2 - I have renamed the files in various ways. If you leave a blank space in the name, joomla doesn't upload the file anyway.
3- This is a complete fresh site, no other extensions yet, except your template.
Besides, it is not so, that the slideshow does not show any images at all. At this moment I have stored the files in the loomla header-folder. There were allready some default joomla images in the folder, which are shown perfecty.
Idea! I just see that all my files end with JPG, the other files have jpg as extension. I will change that first. I'll let you know the result.
Tadaaaaa, that dit it.
:P
So no capital extensions... Maybe you can add that to the troubleshooter.
Thanks for now, maybe til later. I have some more sitebuildwork to do ;)
