1. squazy
  3. Monday, 19 August 2013
Hi I have downloaded the LetterPress template and have installed it now.
I have tried to set up the slide show module but nothing shows up on the page. My website is live at the moment so I have the LetterPress template on one page only that is visible to registered users only for the moment.
The only difference when I enable the slide show is that it makes the article that is visible under the menu move up higher so it is behind the menu bar.
May I suggest sending temporary administration access to your Joomla installation to [email protected] and we will examine this issue further. For our reference please paste a link to this post in your email
I have sent you an email now.
Thank you Maureen
I have enabled jQuery within the modules parameters and it appears to be now working correctly.
