1. ScottN
  3. Thursday, 20 March 2014
I'm trying to edit the slideshow in Arkadia template.
I've installed the template from the demo installer but I also installed the mod_j51slideshow.zip through the extension manager. It appears to install fine and in the module manager I can access a module called "Slideshow" but there is no option to add more slides anywhere in here - is it not possible to add more?
If it is the same or similar to the Calibra template, the Slideshow module will have a field called Image Directory on the settings tab, where it shows which media folder it is looking to, for the slide images. Possibly images/banners/
You need to add the slide images via the Media Manager, not the slideshow module itself, to that images folder and then they will automatically appear in the slideshow.
Apologies if it isn't the same, but quite possibly it will be. :)
