1. papermakeit
  3. Sunday, 04 August 2013
I'm just now trying to set the slideshow on Arkadia. Is it Firefox 22 that has got issues? Not every effect is applied correctly. I left one of the many that doesn't work on the test site: http://www.new.papermakeit.com
The installation is just that coming from Demo Installation and everything went right. Then I upgraded to the latest version of Joomla. Then I installed the last release of Virtuemart. That's all.
Horizontal or direction left or fade (single) work well.
Many thanks.
To amend try adding the following to the Custom CSS field of your templates parameters..
.container_skitter img {
max-width: none !important;
Custom CSS solved completely the issue.
Many thanks!
