1. ColDee
  4. Wednesday, 05 June 2024
I'm using the J51_LayerSlideshow module.
The Slide Title disappears in mobile view. You can see an example here: https://hansglobalsecurity.com/about-us
Can you let me know how to fix this. Thanks.
Regards,
Colin.
Hi Colin
Try reducing both fields in the Responsive Settings tab to 0.
Thanks, they are showing now. They aren't centred vertically though. Is there a way to fix this?
Regards,
Colin.
.layerslideshow .info {
padding-top: 0 !important;
I am using Nina and have the same problem.. I have put the settings to 0 and entered the css, no luck!
Any help much appreciated
Peter
