1. abseve
  3. Sunday, 20 April 2014
I customized letterpress where there is no hornav. When I turned off responsive the slick nav menu appears on the top left corner of the screen.
See attachment.
Hi Abseve
Thank you for bringing this issue to our attention. To resolve the problem you can simply re download the template and install via your Extensions Manager.
Alternatively you can replace the following in your templates scripts.php (../templates/j51_letterpress/php/scripts.php)...
<!-- Hornav Responsive Menu -->
<script type="text/javascript" src="/<?php echo $this->baseurl ?>/templates/<?php echo $this->template ?>/js/responsive-nav/responsive-nav.js" charset="utf-8"></script>
jQuery(function(){
jQuery('#hornav').slicknav();
</script>
With...
<?php if($responsive_sw == "1") : ?>
jQuery(function(){
</script>
<?php endif; ?>
