1. Oliver
  4. Thursday, 09 April 2020
I want to use the layerslideshow_lite of the new Skylar template. It seems to be a new version of the layerslideshow module used in the templates before. But it does not support the alignement option in the image settings. Is this correct? I tried to use them but they have no effect.
What I need is a textarea (with title and caption) that can be aligned to right, center or left like the older layerslideshows did.
So I installed the layslideshow module of Ensley template but it does not work with the template correctly. E.g. the navigation arrows appear in the maincontent area.
How can I modify the module to support the alignement option? Is this possible?
Oliver
Hi Oliver
div.layerslideshowlite .item-align-left .info {
align-items: flex-start;
div.layerslideshowlite .item-align-center .info {
align-items: center;
thank you very much.
It works :)
Oliver
