1. dautrich
  4. Sunday, 07 June 2020
I’ve set up a site using Skylar template and get 403 errors in at least three different scenarios. The site has some minor user CSS in custom.css.
Site setup:
- There is only one public page, like a portal, as the site root. It shows some infos about the site and a login form.
- There are also two pages for Legal Disclosure and Privacy Declaration, available from the footer menu, but these don’t matter here.
- Any other content is only visible for logged in users. Technically, all respective articles and menu items are set to access level “Registered”.
- One of the menu items is of type “Menu Heading” and is used to display a submenu.
403 errors show up in these cases for logged-in users:
1. When he clicks on the site title.
2. When he closes his browser without logging out.
3. When he clicks on the menu item of type “Menu Heading”. (There is no error, when he clicks to a submenu item.)
In any case, the site remains unusable until the previously logged-in user’s session is killed in Joomla backend. I even experienced some situations where I had to deactivate and reactivate the respective user.
As a temporary solution for 1. I've removed the title link from inc/layouts/logo.php.
As a temporary solution for 3. I've prepared a dummy article and display a "Single Article" instead of a "Memu Heading".
I’ve prepared a demo site with only a minimum of content, but containing the complete site structure. I also prepared a test user (User Name: test / password: test) and a Superuser (User Name and Password will be sent to info@joomla51.com).
Attachments (3)
  1. https://systemtest.nickdautrich.de/
It is rare that 403 errors would be related to the template. They usually indicate a user trying to access a resource that they do not have the rights to. An example would be opening an article with access set to 'registered' by a non-logged in user. Just to confirm that this is a template related issue, could you try enabling one of the default Joomla templates (Protostar) and see if the issue still exists.
I've changed the template to Protostar. That gave the following findings:
Clicking on the site title:
- When not logged in, everything is okay.
- When logged in, a 403 is thrown. The frontend is unusable. I have to kill the user session to make it usable again.
- The problem can be solved for me by removing the <a>-tag in index.php (or in logo.php). No issue for my site.
- Do you see this as a bug in Joomla? If yes, I should report it.
Closing the browser
- For my website, this is a serious problem.
Clicking on the menu item of type “Menu Heading”
- In Protostar, a menu item of this type is not clickable (s. attachment).
- In Skylar, such a menu item is clickable and throws a 403.
- Your template behaves differently from Protostar.
- I can resolve the issue by using a dummy article and changing the menu item to type "Single Article". This is not elegant, but works.
If you want to play with my site, feel free to use the credentials I sent to you via e-mail.
Kind regards,
Rolf
Hi Rolf
Thank you Rolf
The issue appears to be related to your permissions. I have amended your 'registered' access and all appears to be now working correctly.
Can you pls explain what you have done to my registered access?
Thx, Rolf
I just tested, but the issues remain as described.
Hi Rolf
On which user are you having this issue?
With all users. I tested with users 'rolf', 'test', and 'dautrich' (Super User).
When we log in to your site with test we can access all menu items under 'Jahre'. Was this part of your original issue?
No, if you click on the submenu items, it works. But if you click on "Jahre", the site throws a 403.
In Protostar the menu item "Jahre" is not clickable, in Skylar it is clickable.
I have changed your "Jahre" menu item to a separator which resolves the issue. The menu heading was linking back to your homepage, however as your homepage menu item is only allowed to guests, it was giving you a 403 error.
I appreciate your help. Setting the menu item "Jahre" to separator solved the issue.
I also set the menu item for the homepage to access level "Public". Originally, I didn't want this menu item to appear when logged in (therefore the access level "Guest";), but I can live very well with the "Public".
You can set the issue to "closed".
Thanks and best regards,
Rolf
do you still need access to my site? If no, I can change the admin password or remove the test site completely.
Regards,
Rolf
Hi Rolf
No, we no longer need access to your site. You can now change admin account password.
