1. dautrich
  4. Friday, 04 August 2023
I have a small issue with Skylar's CSS: I tried to adjust the padding-bottom for class ".contentbottom .module_surround". But this is hard-coded with an "!important" in nexus.css:
Would it have negative effects to remove the !important there?
Rolf
Hi Rolf
We have created a new update for our Skylar template including this amendment.
will you remove the !important directive from nexus.css (lines 2079 and 2082, see screenshot above) in the next version of Skylar_J4? To do so would help me a lot, because then I can change the values in custom.css without fiddling around with the nexus.css versions on each template update.
Thx and regards
Rolf
Hi Rolf
I can't think of any negative affect if removed.
