1. dautrich
  4. Saturday, 24 December 2022
In my sites, I extensively use the CSS class 'caption' with template SKYLAR. Here is an example screenshot from the J3 version (s. SKYLAR_J3_Caption_ok.jpg). The image caption is displayed as expected.
In J4, the caption is not displayed (s. SKYLAR_J4_Caption_missing.jpg).
The HTML code of the article is identical for J3 and J4 and is shown in HTML_Code_of_Article.pdf.
The custom CSS is more or less identical for J3 and J4; all entries for all kinds of captions are identical. See my J4 custom.css in custom.css.pdf.
I also would like to bring to your attention that the display of the figure-element is not identical in the J3 and J4 versions of SKYLAR. In J3, the figcaption is inside the border of the figure-element (s. SKYLAR_J3_figcaption.jpg), whereas in J4 it is outside (s. SKYLAR_J4_figcaption.jpg).
Rolf
Attachments (5)
Hi Rolf
Thank you for the update.
As the code may have an effect on the 'Joomla 4' method of adding image captions, it is unlikely that it will be included with the template but good to know that the code now works and can be added as needed.
That looks perfect!
Question: Are you going to incorporate that patch into the next version of SKYLAR_J4? If not, I'm fine with the custom code.
I assume that you don't need access to my sites anymore. Therefore, I will deactivate your Super User account and re-activate the .htaccess on the admin directory.
Thanks and regards
Rolf
Hi Rolf
Assuming your caption class is on your img element, you can amend the code to the following...
<script>
document.addEventListener("DOMContentLoaded", function() {
const imgs = document.querySelectorAll(".maincontent img.caption");
for (const img of imgs) {
const caption = document.createElement("p");
caption.classList.add("img_caption");
caption.innerText = img.getAttribute("title");
img.after(caption);
</script>
Sorry, but your code does not provide compatibility between the J3 and J4 versions of SKYLAR.
Your code for the J4 version adds a caption to all images, whereas in the J3 version an image-caption is shown if and only if the class caption has been added to the <img> tag. This also leads to double caption in <figure> elements. This can best be seen here: https://staging.nickdautrich.de/lebensjahre/2008
Is it possible to test for the caption class in your Javascript?
Rolf
To amend we have added the following to the Custom Code -> Head Custom Custom of the Custom Code field of your template style settings...
<script>
const imgs = document.querySelectorAll(".maincontent img");
img.after(caption);
</script>
Hi Rolf
All we require is superuser access so we can amend your template.
What type of admin access do you need (in addition to Superuser access to the J! Backend)? FTP access?
Rolf
Hi Rolf
Thank you for allowing us access to examine this issue.
Unfortunately this appears to be an issue with Joomla 4 as it uses a newer version of the Tiny MCE editor which no longer dynamically grabs the caption from the title attribute. Instead, you must now set the caption separately once enabled via the image edit.
If you wish you can set us up with temporary admin access and I will attempt to add the JS required to re-enable this feature.
Hi Rolf
