1. dautrich
  4. Monday, 25 March 2024
I just noticed that in Skylar-J4 the icon for the mobile number is not displayed correctly on the Contact page:
Could you pls check!?
Rolf
  1. https://www.upgrade.hasenritter.de/kontakt.html
Hi Rolf
Checking the URL provided, it seems that none of your icons are rendered?
Sorry, I used the site for PR testing and had to set it up again. In this process, I forgot that I had used the site for this post. And because the icon for the mobile number doesn't display correctly, I had set the configuration parameter in my live site to "Text" instead of "Icon".
Now I have set it back to "Icon" and you can see that all the other icons on the contact page (I don't know about icons not displayed) display correctly, apart from the one for the mobile.
Please check again!
Rolf
Hi Rolf
Thank you for the update.
Replace me with the text you want to insert...To amend try adding the following to the Custom CSS field of your templates parameters (Extensions -> Templates -> [YourTemplateStyle] -> Custom CSS)....
div div [class^=icon-]::before, div div [class*=" icon-"]::before {
font-family: "Font Awesome 6 Free";
Thanks for the patch. That does the trick!
Regards and Happy Easter
Rolf
That's great... thank you for the update.
Have a happy Easter :)
