1. dautrich
  4. Sunday, 07 June 2020
Is it possible to provide Google fonts and Font Awesome from local site with Skylar?
How to achieve this?
By default FontAwesome will be loaded locally with your template.
For Google fonts you will need to upload a copy of your Google font to../templates/[YourTemplate]/fonts folder.
To import these files you can add the following to the Custom CSS field of your templates parameters..
@font-face {
font-family: 'YourFont';
src: url('../fonts/yourfont-webfont.eot');
src: url('../fonts/yourfont-webfont.eot') format('embedded-opentype'), url('../fonts/yourfont-webfont.woff2') format('woff2'), url('../fonts/yourfont-webfont.woff') format('woff'), url('../fonts/yourfont-webfont.ttf') format('truetype'), url('../fonts/yourfont-webfont.svg') format('svg');
font-weight: normal;
font-style: normal;
Lastly you will need to stop the template from loading your font from Google by removing the following from your templates ../templates/[YourTemplate]/inc/fonts.php
foreach ($googlefonts as $v) { // loop
$app->getDocument()->addStyleSheet('//http://fonts.googleapis.com/css?family=' . $v . ':' . $font_weights . '&&subset=' . $font_subset . '&display=swap');
There is also the following detailed description on this topic... https://www.joomla51.com/forum/google-fonts-eu-dsgvo?start=20#reply-34691
Local loading of Google fonts done! Thank you for your explanation!
