Where can I find this side module menu in Privilege. I updated the template (I think I don't see the changes) I followed the instructions and it says it updated successfully. Is this something i have to create with side-col a? Thanks
The above is a simple menu module. From your module manager navigate to Extensions -> Module Manager -> New Menu and set the menu in the sidecol-a module position.
Sorry I saw your response after I kind of figured out the font stuff by using this..
.module ul a, .module_menu ul a {
color: #080808;
margin-left: -5px;
font-size: 15px;
font-weight: bold;
letter-spacing: .5px;
text-transform: uppercase;
li {
height: 78px;
float: left;
But when I used the above code it effected every list item on the page, including my #base .module ul a, #base .module_menu ul a.
So I'm not sure how to use the code specific for the these list items only. Using developer I've identified this list as follows:
