1. Mol4
  4. Monday, 13 June 2022
On my clients test website I've managed to get the sidebar B before the component on mobile with the following code (found in the forum):
@media only screen and (max-width: 1010px) {
#main {display: flex; flex-direction: column; }
.sidecol_b, .main-content { order: 0; width: 100%; }
What I tried to achieve is to get the Module Title and the hamburger menu in one line.
Unfortunately not with any success.
Is there a way to achieve this?
Thanks!
Greetings,
Ton
Oke, that is clear :-)
It is a Menu module but I'l try this with a custom module where I place the Menu Module in or so.
Thanks!
Greetings, Ton
Hi Ton
As the module header and content are in two separate containing divs, this unfortunately is not really possible. Have you tried disabling the template header and instead, placing it within your module content (presuming this is a custom module)?
I think I've found a solution for this.
I've put in the next class in the custom css of the template:
.icon-menu::before {
content: "submenu \f0c9";
color: #7A6FAC;
Only thing is after clicking the background remains purple so you don't see the text anymore.
Do you maybe know how to solve this?
Thanks!
Greetings, Ton
Hi Ton
button:hover ::before {
color: white;
Thanks but unfortunately this doesn't work (tested on iPhone 12).
Greetings,
Ton
Hi Ton
Could you try replacing this CSS with the following...
button:hover ::before,
button:focus ::before,
button:active ::before {
color: white;
