1. Tralala
  4. Saturday, 16 April 2022
Working with Nina in J4, the modules in side-column 2 doesn't come before (above) component in mobile view. Although I choosed in template > General > Responsive Options > Sidecolumn Positioning for 'Before Component'.
The (old) solution in https://www.joomla51.com/forum/sidecolumn-positioning-not-working-properly doesn't work.
Your elswhere given option @media only screen and (max-width: 840px) { .sidecol_b { order: 0 !important;} forces the right-column modules to the left – this is not what I want.
How to fix this?
  1. https://www.demo1.ict4free.nl/activiteiten/fietsen
With this given code the content of the column does come first, but in iPad portrait view the column is too narrow.
I choose for this code now:
@media only screen and (max-width: 1010px) {
#main {display: flex; flex-direction: column; }
.sidecol_b, .main-content { order: 0; width: 100%; }
So it needed the addition of "width: 100%".
.sidecol_a, .sidecol_b {
order: 0;
Thanks, but sorry, this is not what I am looking for.
My wish is not 'sidecolumn 2 left of ('before') component' (than I should choose placing in sidecolum 1), but 'above content'. That's what is meant by 'before', isn't it?
Your suggestion did not meet my needs, BUT you gave me an idea.
I added this code:
@media only screen and (max-width: 820px) {
#main {
display: flex;
order: 0;
(820 isn't essential)
and that did the job.
Could you try the following instead...
order: 0;
There appears to some CSS affecting this feature. If the above is not the correct solution for you, may I suggest sending temporary administration access to your Joomla installation to [email protected] and we will examine this issue further. For our reference please paste a link to this post in your email.
