1. asiadragon
  4. Thursday, 16 July 2020
Using Bianca
Is there a way I can 'stretch; a showcase module so it spans over one or more positions as in the graphic attached?
  1. https://www.sproutstory.co/en/home/test-item
Considering all screensize and image ratio, this is only possible by cropping the slideshow image. Is this suitable?
OK, is it possible to merge modules together - Where the slideshow spans say 3 showcase modules whilst having a 4th - 75-25%
You can adjust the width of module positions via the Module WIdths tab of your template settings. For details on placing modules inside a module may I suggest the following article.. https://docs.joomla.org/How_do_you_put_a_module_inside_an_article%3F
