1. erikoraka
  4. Saturday, 14 September 2019
I am trying to set the showcase background color in the following homepage http://www.syndesmoskentrikiadon.gr/ so as to be filled from one side of the screen to the other as it is showed in the following example: https://www.joomla51.com/demo/0158/index.php/example-styles/example-styles-4. I am referring to the purple color.
Can you advise how?
I tried to add the following css to the custom field: #container_showcase1_modules {background-color: #4f2844;} but I see no change.
Also when I set the color in the field of the module styles override I do not have the same result as your Chloe template referred above..
Can you please advise?
Thank you in advance.
Eri
Hi Eri
To copy the styling found in the template demo you can set the Showcase-1 Background Color field found in the General -> Modules/Component Styling tab of your template settings to #4F2844.
Alternatively, you can enable the 100% Width option in the Module Widths -> Showcase 1 Modules tab. This will extend the module position to 100% width.
Thank you Ciaran!
Best regards,
Eri
