1. Tompakidf2
  3. Monday, 29 March 2021
Is there an easy way to shift the language change buttons (the flags) to the top left of the page, only when the site is viewed from a mobile device? See attachment. I am using Joomla 51 Central. I guess some code editing is needed. Can you assist or tell me where to start from?
Many thanks,
Achilleas
Hi Achilleas
Sorry to say this option is not available with our Central template as each of these elements reside in completely different containers.
Hello Cirian,
OK, thank you. Can you suggest another template that might suit this need?
Regards,
Achilleas
Hi Achilleas
Unfortunately, we do not have a template that contains a module position in the mobile menu area.Would you have a URL to an example of your language switcher?
