Hallo,
i use the modul J51_carousel at position slideshow on the start site of the homepage.
I often need to change the order.
It is possible to change the options for the columns? It would be so helpful, if I could move the columns with the mouse. Similar to modul j51_layerslideshow.
Could they rebuild the modul j51_carousel so?
Or is there a different solution?
Silbis
