1. smbluest
  3. Wednesday, 13 August 2014
I am using the Nocturne template with Joomla 3.2.3. I am using the ImageLinkHover module for several image links on the Home page of my site. When the text is not exactly the same in each "box" (module), the heights differ. I have only been able to get a uniform height by adjusting the image sizes accordingly.
What I would like to do is have the same image dimensions for each box but always have the boxes be the same height no matter how long or short the description text is. Is there an attribute I can set to make the module heights the same?
Thank you in advance.
Regards,
Sheri
May I suggest the following article which details the CSS media query needed for each device. This should help you in focusing the CSS to the devices of your choice. Simply replace the '/* Styles */' with your CSS (.bottom-2 h3 {... )
http://css-tricks.com/snippets/css/media-queries-for-standard-devices/
I have tried both @media only screen and (max-width: 959px) {
and @media only screen and (max-width: 768px) {
neither seems to be working to change the font size of the titles.
Hi Sherri
What is the first line of the CSS you are using to edit your h3 text?
Eg.
Hi again,
Sorry about this, but the fix looked ok on my computer with re-sizing the screen to iPad dimensions but when viewed on an iPad, the titles in the ImageLinkHover boxes are not being resized. I have attached a screenshot of the issue in question from an iPad.
Your login info remains the same.
Thank you,
Sheri
I think I figured it out. I changed your CSS to:
.bottom-2 h3 {
font-size: 18px;
and that worked to change the titles on the second row of ImageLinkHover boxes. I think it's good now.
Thank you for all of your help!
I just tried that out and changed the title font size to 12 but that didn't seem to change anything on the iPad. Actually what I do notice is that the titles of the first row of imagelinkhover boxes has been resized but not the second row. So we are getting closer.
Try extending the max-width of your media query to 959px...
.j51imagelinkhover > p {
min-height: 230px;
.bottom-1 h3 {
font-size: 18px;
I've added the following to the CSS:
min-height: 250px;
.bottom-1 h3 {
font-size: 11px;
but the ImageHover titles don't seem to be adjusting on the iPad (in portrait orientation). The Backcountry Scouting title is still too long and is making the box longer than the others. Any ideas?
Sorry... I got it :)
Could you try adding the following to the Custom CSS field of your templates parameters....
min-height: 230px;
.bottom-1 h3 {
font-size: 18px;
The first part of this sets the min height of the module. Due to narrow width the height has to be extended to accommodate all the text. And the second part sets the title to keep it on one line.
Hi Sheri
Would you have a URL to an example of yoru ImageLinkHover modules?
Hi!
Now the imagelinkhover heights are great for full-screen but they are not uniform on a tablet. Could you please provide CSS for forcing the same height for all of the boxes on a tablet?
I tried:
.j51imagelinkhover h3 {
font-size: 11px;
but I think that I need the code to change the TITLE font size so that Backcountry Scouting will fit on one line. Thank you! I will send the login information to you in an email message.
Thank you!
Regards,
Sheri
That did the trick! Many thanks for your quick response!
Thank you Sheri
To set a min height to your ImageLinkHover modules try adding the following to the Custom CSS field of your templates parameters (editing to your taste)..
min-height: 120px;
I've responded by email to your request.
Hi Sheri
Would you have a URL to an example of your ImageLinkHover modules so we can examine this issue further?
