1. bibbp
  4. Friday, 17 January 2020
Ciaran,
I have just purchased a new copy of serenity hoping that it eliminates a screen build issue. Unfortunately it has not worked. Please go to the url listed below and see that the menu items appear as a list before the template actually loads.
  1. https://www.scottsproject.org.uk/
Are you running any kind of optimizing plugin? Is this a new issue?
I am using JCH Optimize Pro, I have had to use it because the website was loading too slowly.
Also, how do I remove the small copy of the menu item title from under the title? (from the sub-menu items)
You appear to have set up JCH Optimize to load your site CSS after the DOM has loaded. Changing this should resolve the issue.
The menu item tagline is set via the Link Title Attribute of your menu item settings.
Thanks Ciaran, can you tell me the offending option in JCHOptimize, it’s not clear to me.
Ciaran, re: "The menu item tagline is set via the Link Title Attribute of your menu item settings".- that field is blank in every case.
I stopped the Optimze CSS delivery, which seems to have cured the screen building problem. Still have the menu item title issue. Thanks
Regarding the tagline, may I suggest sending temporary administration access to your Joomla installation to [email protected] and we will examine this issue further. For our reference please paste a link to this post in your email.
Taglines to your sub menu items should be now hidden.
