1. toms-office
  3. Saturday, 06 October 2018
hi, i have the same problem with j51-serenity. i want to use a *.png-picture (logo with background transparent) in the template. i have added the code:
.logo {
border-color: transparent;
box-shadow: none;
in the field "custom cms" and saved. the logo is still appearing still with a white background. can someone please help me.
.logo {
    border: 0 none;
    box-shadow: none;
    padding-top: 6px;
thanks for your new message. i have tried like you wrote. but it still does not work.
I have already sent (e-Mail) logindata for you.
kind regards
I tried that code & it didn't work for me in Asley. http://www.katmandhu.com
(Switched to this, I just didn't like BOSS for this site.)
My logo is a transparent .png, so I think it would look better.
Thanks,
Kat
  1. http://www.katmandhu.com
Hi Kat
You appear to be using the Ashley template. Would you like the entire header area to be transparent (have backgound image behind logo) ?
Yes, but only on certain pages.
Been along time. Hope you are doing well.
I picked Ashley because the logo could be large enough for my taste.
I love all the new templates you've made since I have come back to haunt you!
Thanks for the reply,
Kat
Hi Kat
Good to see you back :)
To amend try adding the following to the Custom CSS field of your template settings..
#container_header {
.hornavmenu {
    background-color: white;
    padding-top: 15px;
Wow! That works perfectly! Many thanks!!!
  1. https://katmandhu.com/index.php
Dear Ciaran,
I love it so much, I've made all my header logos transparent. It just makes the background images look so much cooler and gives depth to the site! I need more!
Can you figure out a CSS that I could add to make everything under content down to footer transparent also. SIDECOL-A & B would be awesome too.
Sorry to come back and bug you again, but I swear this is the last until I start working back on bargoddess.com. I found a new template that I think will work better, but not for awhile. Gotta get this one going. (Neglected far too long.)
Thanks,
Kat
Hi Kat
You appear to have already found a solution? Checking your site and it appears the footer of your site is now transparent?
Footer yes, that's standard with this template. I'd like Bottoms, Bases & Side Columns also.
#container_bottom1_modules,
#container_bottom2_modules {
Sorry to say it is not possible to make the background of the side column transparent without effecting the component area.
Bottom works like a charm! Thanks!!!
I tried adding BASE, but no luck.
Would you have a URL directly to an example of your base modules?
I have a page that I am playing with an idea for.
You have to look at the Showcase position also! I'm not sure if it got copied over from my other site or what, but I LOVE the looks of it for some reason! WTF? But I am gonna use it! I don't know if this template even has that position!
Here's the link to both in question.
https://katmandhu.com/index.php/katmandhu-designs/etsy-showcase
Want to be able to make these transparent.
No hurry & thanks for all you do for me!
Kat
Thank you Kat. Looking good.
To amend the background of the base modules, try adding the following to the Custom CSS field of your templates parameters (Extensions -> Templates -> [YourTemplateStyle] -> Custom CSS)....
#base1_modules {
#base2_modules {
Once again, it works perfectly!
Thanks!
