1. erikoraka
  4. Wednesday, 07 December 2016
I have a problem with Serenity template and OpenGlobal Categories Module for VirtueMart, which does not display at all in the side column of the template.
Here's the link: http://www.gw-thegreekwineroutes.com/en/gwinsider/wineries
Can you please advise?
Thank you,
Eri
Hi Eri
In what position have you placed your module? I am unable to locate it in your source which would indicate a non template issue.
The module is published in position sidecol-1c in the following url: http://www.gw-thegreekwineroutes.com/en/gwinsider/wineries.
But I don't know the reason why it does not appear..Is there a conflict with the template or something is wrong with the module?
Do you have any idea?
Thank you again,
Eri
There does not appear to be any sign of your module in this position within your source. Can you confirm that you have the correct menu assiginment that within your module settings? Does your module work in any other module position?
