hi, i am trying to use a booking system that embeds into a website but they are telling me to add a line of script to the header of every page. they say it goes somewhere in the template??
do you have any idea please?
am using j51_virtuoso
thanks
- Balmmnd77
- Wednesday, 16 November 2016
Sorry but I believe you misunderstood me. I meant sending an email to the developer of your quick-book.js extension. This is not a Joomla51 script.
no i just need to know how to get their script above all the other scripts in that list please. do you lknow where in joomla files to put it as they do not know how to get he script to be on top.
thanks
thanks
Try placing your script before the following in your templates index.php (../templates/[YourTemplate])...
This is where Joomla adds all it's head data.
<jdoc:include type="head" /> This is where Joomla adds all it's head data.
As you have carried out what they have recommended I suspect this is more likely a script related issue. Have you tried contacting the script developer?
Have you tried adding your code to the 'Body Custom Code' field? This will render your JS call at the end of each page, just before the closing body tag.
thanks but it seems to have no effect..
this is hat the developer said just....
We would suggest that you put the script <script src='https://www.bouncycastlenetwork.com/quick-book.js'></script></div> towards the top of the page, ideally before the rest of the Javascript, rather than at the bottom of the page, or in a place that would make sure it loads first.
hi
iplaced <script src='https://www.bouncycastlenetwork.com/quick-book.js'></script></div>
</head>
still casused a problem.
if you clock book button before page loads the booking system loads outside the template.
if you wait til it loads template it is fine.... any ideas plase?
</head>
- # 9
You can add your code to the templates index.php (../templates/j51_virtuoso/index.php) You will recognise within this file, head and body tags similar to a normal HTML file.
- # 10
