I changed the background color, but there doesn't seem to be an easy way to change the font color for the entire sidecolumn. Thanks in advance for any help you can provide.
Update: I was able to make the css change to the headings of each item in sidecolumns, but the menu items are still unchanged. So all I need to know is how to change the menu item colors in a sidecolumn menu.
Edit to taste...
.sidecol_block ul a {
color: #aaaaaa !important;
