1. pauledwards
  3. Sunday, 14 October 2018
Recently bought Robyn template, some slight modifications needed for my website before trying it live. I have setup Xampp localhost server, installed the demo, works great, but i do not see the search box anywhere. I have installed the template in my website on localhost to see how it looks, the search will not display in the HORNAV position, can get it to display in header 1 & 2, or side column, but not HORNAV, what could I be doing wrong. Also the search button does not appear to work when clicked either.
Cheers
Paul
Done some work on the template today, and I have placed the search box in left side column, seemed best place for it, also adjusted size of button, all seems to be working now. Will be putting it live sometime tomorrow, hopefully.
One or two tweaks still needed so might some more help.
The template looks great
Cheers
Paul
Hi Paul
Can you confirm for me that you have enabled the hornav module position in the General -> Menus tab of your template settings? By default, this template will display a menu of your choice rather than the module position.
