1. pedra
  4. Saturday, 02 July 2022
is it possible to move the icon for the mobile view (hamburger menu icon) from the right side to the left side?
First of all, thank you very much.
Maybe try adding the following to the Responsive Custom CSS fields within the General -> Responsive Options tab of your template settings. For more details on using these fields may I suggest the following article... https://joomla51.com/tutorials/template-parameters/applying-custom-css-to-a-screensize-device
.header_main {
flex-direction: row-reverse;
justify-content: space-between;
padding-inline: 1rem;
.logo {
flex: 0 1 auto;
Hallo Ciaran,
thank you for the help. Your suggestion works as desired. :)
As the logo is by default to the left side, would you like the swap the position of the menu toggle and logo?
Hallo,
That's exactly what I thought. It would be great if that were possible.
Perrette
