1. Arunas
  3. Tuesday, 10 September 2024
Hello, I need some help! Should Revolve work with Joomla 5.1.4? I have tried to install Demo version and getting the same message all the time: JInstaller: :Install: Can't find Joomla XML setup file. Please I need some help, because stuck with the problem for couple of days. Thank you
For details on setting up the template demo installer may I suggest the following articlle.. https://joomla51.com/tutorials/troubleshooting/error-cannot-find-joomla-xml-setup-file. It sounds like you are trying to install the demo via an existing Joomla installation which is incorrect.
Hello Ciaran, I have checked the tutorial (https://joomla51.com/tutorials/troubleshooting/error-cannot-find-joomla-xml-setup-file), but no success. I have unzipped the Demo Installer folder into it's own folder, copied files, but the same message. See attached picture, maybe there is something i don't get it.
What do you see if you open the URL in your browser to the root of your demo folder which you have uploaded? Assuming you have no configuration.php, you should be directed to the Joomla install.
Hi, how do I look for that ROOT in my browser? I have installed Joomla, then in the TMP folder of Joomla_5 have uploaded Demo Installer unzipped files. Thanks
Did you read: https://joomla51.com/tutorials/demo-installer/setting-up-the-demo-installer
If you already installed joomla 5 you only need to install the template.
