1. RoliMeier
  4. Thursday, 02 March 2017
Hi, I work with the new London-Template. I use the J51_LayerSlideshow on the position showcase. Everything is fine but not on Mobile. Can you please have a look on http://www.3c-beratungsportal.ch.
Thanks a lot
  1. http://www.3c-beratungsportal.ch
.touch .layerslideshow .item h2 {
font-size: 24px;
.touch .layerslideshow .item h3 {
font-size: 14px;
Solved it,
Added some code you posted in another thread:
.layerslideshow .info {
display: block !important;
Thanx Ciarán:)
.layerslideshow .img-fill img {
max-width: 260%;
Tnx, that did make it work !
Your text color should be now changing correctly. We have replaced the suggest CSS with the following (adding !important)...
[code].layerslideshow .item h2,
color: white !important;
}[code]
Could you detail for me the issue you are having on mobile devices?
Dear Ciarán, I have problem if i define the slideshow then I see on the mobile device nearly nothing or only fragments. Roli
Hi Ciarán,
I have the same problem with the same template. I have some text and a link in the layerslideshow, but none are showing or working on mobile device.
I have my layerslideshow in position top-3a, and put the code mentioned above in the template custom CSS, both in the man and the responsive css, but neither worked.
Please help.
Baljinder
Hello Ciarán, hello balosingh,
I have the same problem.
Look : http://www.ji-consult.be/fixingyou
On mobile, the text on the slideshow is not showing up (iphone 7). When you tilt the mobile device, it's working.
So I added the code from balosingh, it's showing up now, but the first text is only showing a part of it.
Instead of putting : 'mind body soul' it only puts 'body'.
Hello again,
I have another question for these layeredslideshow : can I use a different color for the font, so that when you display this on a phone, let's say, the font is Very light (withe ...) or something, and if used on tablet, it's dark green or something. Is it also possible to change the font itself?
Using the Custom CSS fields in the responsive Options tab of your templates parameters you can add the following CSS (edit to taste)...
color: white;
Hello Ciaran, tnx for the reply. However... this doesn't seem to be working.
Take a look at http://www.ji-consult.be/fixingyou
Tnx ! You're the best. For me it just keeps difficult sometimes to pinpoint the exact place of where one should tweak some css code, to get the desired action.
Any (online) css course recommendations?
Your best friend in situations like this is the 'Inspect Element' option in your browser (Right Click -> Inspect Element). At the top of the list of rules you will see a plus sign. Clicking this will give a recommended selector for that element.
