1. broman
  3. Wednesday, 04 February 2015
I'm using the template Polaris and made some adjusments but after finishing the site there is no menu (on top of the site) visible on the site on mobile devices. It is only visible when a set responsive options on NO; at this moment the site is offline but you can login to see the site with:
The site : www.daansq.bro-man.nl user "bezoek" and password "ingerman" (without the " ";)
I have already tried if it matters to make a module position of the hornav menu but that does not make any difference.
Kind regards
To ensure the issue isn't related to any installed extensions try disabling any 3rd party plugins To disable 3rd party plugins navigate to your Plugin Manager (Extensions -> Plugin Manager). Sort your plugins by ID in decending order. 3rd party (non Joomla) plugins will be listed first and will have an ID number significantly higher than your Joomla plugins which will usually be in the 400 to 500 ID range.
Does this resolve the issue? If so try enabling each plugin one by one until you find the conflicting plugin.
I'm sorry, I've tried this but it does not solve the problem!
