MENU
  1. didiermarcelfernand
  3. Sunday, 29 January 2017
Ladies and gentlemen, hello
I use J51 Privilege for quite a while but since the update of joomla 3.6.5 it seems to me that the menu in mobile version no longer works correctly. The submenus can no longer be displayed on the screen.
You can do a test on our website at http://www.voltaire-joffre.com
Thank you for your answer in advance.
Have a good day.
Regards,
  1. http://www.voltaire-joffre.com
As there appears to be some Javascript conflicts with your mobile menu may I suggest the following article... https://www.joomla51.com/tutorials/item/resolving-javasript-errors-in-joomla-using-jquery-easy
Hello, after installing jquery-easy the problem has gone. Thank you for your help.
Have a good day.
Regards,
Excellent... thank you for the update!
