I have a problem with the Responsive layout and the setting for the logo.
When I use a logo with text, the text is not mobile display smaller: http://gasthaus-zur-linde-eystrup.de/ Text :: "Gasthaus zur Linde" . If I use a logo as an image, the image is not displayed smaller: http://helms-hotel.de/
What am I doing wrong?
There is yet another problem. The contact form: http://gasthaus-zur-linde-eystrup.de/index.php/kontakt is not displayed correctly. This is so not only in this installation, but also to other pages.
I am using Joomla 3.3.0 and the template: J51_Metropolis - Standard
regards
Uwe
- poeppel
- Wednesday, 21 May 2014
Hi Uwe
To reduce the size of your logo on smaller screen devices may I sugges the following tutorial... http://www.joomla51.com/tutorials/item/re-sizing-your-logo-for-smaller-screen-devices
To reduce font size of a text based logo on smaller screen devices you can add the following to the Custom CSS field of your templates parameters where 36px is your new font size..
Could you detail for me in what way your contact form is not displaying correctly?
@media only screen and ( max-width: 767px ) {
h1.logo-text a {
font-size: 36px;
}}Could you detail for me in what way your contact form is not displaying correctly?
Hi Ciarán
Your help worked.
I was able to customize the logo as an image and logo as text.
Thanks for the solution!!
The problem with the contact form is complicated.
I have made two installations with the template Metropolis and both installations I have the same problems.
I then made the demo installation and here I have the same problem.
As I have now found out this is not just the Responsive layout.
Under: http://metropolis.poeppel-media.info/index.php/j-stuff/singlecontact is my demo installation
Here, the formatting in the ordinary screen do not.
In Responsive layout is there more problems.
Perhaps these are related?
greeting
Uwe
Your help worked.
greeting
Uwe
Hi Uwe
Regarding your contact page could you try adding the following to the Custom CSS field of your templates parameters...
.contact dd {
display: block;
}Ciarán
Hi Ciarán
The entry in the Custom CSS field help for the first page: Contact! Here, the data are now displayed in the block!
However, the contact form does not continue with Responsive Options.
greeting
uwe
greeting
uwe
Hi Uwe
I am not sure if I understand you correctly. Your contact form is not displaying correctly on mobile devices? And if not could you detail for me in what way?
Hi Ciarán
I have an image under http://metropolis.poeppel-media.info/bild.png
The font is not less
and the form fields run from the template.
greeting
Uwe
greeting
Uwe
Hi Uwe
May I suggest adding the following to the Custom CSS field of your templates parameters which should help in styling Joomla contact form on smaller screen sizes.
.inputbox, .textarea, .registration input, .login input, .contact-form input, #jform_contact_message {
width: 145px;
.hasTooltip.required {
text-align: left;
}}Ciarán
Hi Ciarán
Your solution works!
My problems are solved.
Thanks for the help!!
Still a nice week
regards uwe
Still a nice week
regards uwe
