1. erikoraka
  4. Thursday, 10 November 2022
I noticed that the css code I put in the responsive css for the phone (portrait) is not applied to the phone but the desktop instead. Please take a look at the page I am referring to:
https://www.arthrojoint.gr/rotiste-to-giatro
The template I use and put the code is the following:
J51_Emani - Ρωτήστε το γιατρό
More specific I try to set the slideshow heading title in the phone to have smaller font size. And I notice that in the phone landscape it is working but in the phone portrait it does not. Also I notice that although I do not change anything in the general css of the template the size of the slideshow title changes to that of the phone landscape and it does not remain the default.
Can you please check and advise?
Thank you in advance.
Best regards,
Eri
Hi Eri
I sent you the credentials in the email you indicated.
Thanks again.
Eri
Thank you Eri
Which of your template styles is assigned to the page displaying your LayerSlideshow module?
The template with the number 22.
Best regards,
Eri
There appears to be some invalid CSS in your Custom CSS field which is affecting the remaining CSS including that of the responsive options tab (eg. ++++ before a selector). Removing all invalid CSS should resolve this issue for you.
