I'm using Resonate template for half a year now, and i recently bumped into few problems trying to modify  it.
1. I replaced the original menu with maximenuck and bought the mobile version of it. But on a mobile device appears the maximenuck normaly on top and the menu from the template in form of link text over the other images on the top of the page and also on the bottom. is there a way to disable them on mobile mode?
2. The main Autsonslideshow is not appearing correctly on mobile device. Is there a way to fix it or to remove it on mobile. And if it can be fixed can i use smaller pictures for the mobile version as the bigger ones are slow to load.
3. I setup j51thumbs and when i click on some of the images it opens the jpeg only and  not a gallery with all the images with navigation. As i read on the forum it must be something with jquery but i couldn't find how to fix it.
My site is: http://www.drtaskov.com
Looking forward for your answers.
