1. Booksie
  3. Sunday, 05 January 2014
I just installed the Resonate template on my Jooma 3.2.1 and more than half of the Template Manager: Edit Style options do not respond. These are:
1) Responsive Options
2) Module Widths
3) Copyright Information
4) Social Media Icons
5) Custom CSS
6) Custom Code
7) Menus assignment
As I just said, the options above do not respond when I try to access them.
Can anyone indicate the problem with this issue I am facing?
Thanks and regards...
I would really appreciate some help on my issue.
Can anyone tell me what the problem is?
Hi Ciarán,
I just emailed you the information requested.
I have re-installed your template and it appears to be now working without issue.
Thanks.
Do you think I have a corrupted version? As I tried to install it twice with the same result.
I can't really say for sure. If your download was corrupted it usually wouldn't even unzip for you. Possibly and issue when uploading to your server.
CIarán
