1. mediafrog
  4. Friday, 16 May 2014
hi ciaran,
I won't show the logo and the transparant banner in module showcase. how to delete the banner I know, but how can I deactivate the logo?
best regards
grit
HI Grit
To disable the logo area try adding the following to the Custom CSS field of your templates parameters...
#logo {
display: none;
hi ciaran,
thank you for this solution. it works fine.
but my client want now to have the logo and main menu banner more to the bottom of the showcase-module. how to do this?
regards
grit
Hi Grit
Not sure if I understand you correctly. Would you have a URL to an example of your logo and slideshow?
sorry ciaran,
I forgot the url...
http://www.psizentrumbasel.ch/preview/
my client doen't like the banner with the logo and the menu through the slidehow-picture. he would like it a litte more to the bottom. I hope you understand what I mean.
regards
grit
Hi Grit
You could try adding something like the following to the Custom CSS field of your templates parameters...
#header_items {
top: 95px;
hi ciaran,
thank you, it works fine.
now another problem
please have a look here:
http://www.dach-beratung.ch/index.php/kontakt
on contact I can*t paste a <br />, so it looks not so nice. the data should be all in separate lines.
It would be great if you can answer as soon as possible, I have to show the website tomorrow my client.
regards
grit
Hi Grit
This issue appears to be with your contact settings rather than the template. Checking your site source your address is all in one line which would indicate the problem coming from Joomla rather than the template styling.
