1. Patricia
  3. Monday, 16 December 2013
The navigation on website http://www.stijlgevoel.nl isn't showing correctly right on android devices. The only menu option is Home. Also, is it possible to have the large images on the homepage appear smaller so you don't have to scroll down?
thanks,
Patricia
Hi Patricia
Your mobile menu appears to be working correctly (tested using Android 4.3). Clicking the 'Home' menu item should bring up your entire menu toward the base of your screen. There does appear to be a slight alignment issue with the menu text which can be fixed by adding the following to the Custom CSS field of your templates parameters....
.js .selectnav {
height: auto !important;
padding: 5px 10px;
Which images would you like to change size?
Thanks for your reply Ciaran, and apologies for not responding sooner (christmas holidays).
The problem is resolved so the ticket can be closed.
All the best for 2014.
Patricia
