1. floskin
  3. Friday, 20 December 2013
Hi, Ciarán
Finally, I solved part of my issues using Firefox.
I my property search I have 2 buttons (clear and list properties). I can customize color of clear button from the renovate template. But the list properties button does not catch the color. Just after pressing it and getting the list of properties the blue button turns to grey. And in the modules I have at the bottom side, one catches the color (as at today grey) but another not, and keeps a horrible blue, like list properties.
Any way to solve this?
Thanks in advance !!!
Floskin :)
Would you have a URL to an example of the button which you wish to change?
http://www.bonaterra.net
home page. sidecol b
It appears this button is been styled by your Real Estate extensions CSS. Try locating the following in your extensions realestatemanager.css (../components/com_realestatemanager/includes/realestatemanager.css)...
.house_button a,
.admin_table_47 .blank a,
.realestate_search_button,
input[type="submit"],
input[type="button"] {
color: #fff!important;
text-shadow: 0 -1px 0 rgba(0,0,0,0.25);
background: #006dcc!important;
background-image: -moz-linear-gradient(top,#08c,#0044cc)!important;
background-image: -webkit-gradient(linear,0 0,0 100%,from(#08c),to(#0044cc))!important;
background-image: -webkit-linear-gradient(top,#08c,#0044cc)!important;
background-image: -o-linear-gradient(top,#08c,#0044cc)!important;
background-image: linear-gradient(to bottom,#08c,#0044cc)!important;
background-repeat: repeat-x!important;
filter: progid:DXImageTransform.Microsoft.gradient(startColorstr='#ff0088cc', endColorstr='#ff0043cc', GradientType=0)!important;
border-color: #0044cc #0044cc #002a80!important;
border-color: rgba(0,0,0,0.1) rgba(0,0,0,0.1) rgba(0,0,0,0.25)!important;
*background-color: #0044cc!important;
filter: progid:DXImageTransform.Microsoft.gradient(enabled = false);
-webkit-border-radius: 4px;
-moz-border-radius: 4px;
border-radius: 4px;
-webkit-box-shadow: inset 0 1px 0 rgba(255,255,255,.2), 0 1px 2px rgba(0,0,0,.05) !important;
-moz-box-shadow: inset 0 1px 0 rgba(255,255,255,.2), 0 1px 2px rgba(0,0,0,.05) !important;
border: 1px solid !important;
cursor: pointer !important;
font-family: arial !important;
font-size: 13px;
font-weight: normal !important;
letter-spacing: 1px;
padding: 7px 14px !important;
text-align: center;
text-decoration: none;
white-space: nowrap;
And remove the following within...
Hi, Ciarán
I made the change based on the trust I have on your advice ... because the active real estate component was JEA not realestatemanager ...
And your solution works perfect !!!
Thanks God, faith exists !!!!
And thanks to you for your excellent service !!!!
Floskin
