1. floskin
  3. Thursday, 28 November 2013
1. I am trying to align my j51 set of icons in module 1f (width 60%). I set width of page in 1200. When I choose right alignement, it does not get to the right of the page.
2. How can I assign internal links to the icons?
3. It is posible to add small text below the icons? Some of them are not so clear ...
4. It is posible to get "FAQ" and "?" icons? can I customize?
Thanks in advance !!!
I forgot ... http://www.bonaterra.net :whistle:
1. A your first module is set to 25%, try setting your icons module position to 75%
2. This is the same as external links (eg. http://www.bonaterra.net/index.php/en/geolocalizacion).
3. Sorry to say this option is not yet available with the icons module.
4. At present the font file included with the module only includes does icons listed in the modules parameters.
Thanks for answer. Even beign aligned to right, there is too much gap between righter icon and side of page. can I reduce it?
maybe Icon "contract" should be named "contact"? In the icon module, in details for each icon there is Icon alt text option. can you tell what is that? or it is tag instead of text?
Thanks, again !!!
The totals of your manual width should add to 100 to allow you to use the full width of the content wrapper. As your first module is set to 30 may I suggest setting the width of your icons module position to 70.
The alt text is the alt text to each of your icons for accessibility and SEO purposes.
Hi, Ciarán
I had 30+1+1+1+2+65. I have changed to 30-70 and it looks much better.
Thanks !!!
Hello Ciaràn
Unfortunately, by the icons is no mouse text?
Icon alt text, however, is set?
is there a option that still needs to be adjusted?
thanks nagex
Sorry to say at present this extension does not include tooltips. The alt text field simply to add an alt text to icons for SEO and accessibility purposes.
