1. ziggy
  4. Friday, 23 November 2012
Hi, I'm working on a website and I have a couple of problems that I never had and I think that may be the template Rendezvous ...
[ul]
[li]- First, as is a multilingual site I would like have separate main menus in English and Spanish, but as you can only put a hornav menu for I have to to put it all on the same menu, not something I like it because it generates problems if I want to edit some of the front page of one of the two languages ​​and then save the changes.[/li]
[/ul]
[ul]
[li]- Secondly but of more importance ... when fixing the web to have the two languages ​​(Spanish-English) and enable the language filter plugin ... items that were created as a "category blog" stopped seeing in the version of Spanish site, the articles in category blog are not seen, but as "single item" if they do ... and as I said, only happens in the Spanish version ... never happened to me before, I do not know what to do ... appreciate it assistance with that, it is urgent ...[/li]
[/ul]
Other data, if anything serve are:
The joomla version 2.5.8
PHP 5.3.16
Server in linux
The page is: http://nuevo.hotelmajagua.com/
Thank you!
Hi alejo-dg
May I suggest the following post which details how to convert the top menu area to a module position allowing you to set up a multi-language menu module as normal (Avenue template but will also apply to our Rendezvous template)... http://www.joomla51.com/forum/support/commercial-templates/hornav-module-not-visible-in-avenue#627
I suspect this may also fix your second issue with 'Category Blog' been a menu option.
On a side note this has become a common issue with our templates of late so on future releases we intend to have an option within the templates parameters to convert preassigned menus to module positions.
Hi, Ciaran
I really like the support you give, and that's why I bought several of the templates here, but not the only reason, of course.
Hornav menu it worked perfectly, is fixed, but my second problem persists, the "category blog" does not appear in the Spanish version of the site (which in the case of my client is the principal)
Thanks for the quick reply.
Hi alejo-dg
May I suggest sending temporary administration access to your Joomla installation to info@joomla51.com so we can examine this issue further.
Ok, right now I send you access, I hope something can be done ... : S
Thank you.
All should be fine now.
Your Spanish contact in your contact manager was not linked to a user. Linking this contact to your 'Super Admin' user amended the issue.
You can now delete the temporary account (Ciaran)
Thank you so much! Your support service is the best! :laugh:
