1. MySigma
  4. Tuesday, 01 September 2015
Hello!
Is it possible to rename the template. Currently the template name "J51-[NAME]" is everywhere within the source code. I would like to change it to the customers name ;)
Thank you,
Manfred
Hi Manfred
One option would be to follow these steps...
1. Duplicate your Joomla template folder (../templates/[YourTemplate])
2. Rename duplicate to that of your choice (../templates/NewName)
3. Open duplicates templateDetails.xml and do a case sensitive find and replace for the original name to your new template name.
4. Replace file name of all language files (../templates/NewName/language/en-GB/*.ini)
5. Replace name in first line of each language file
6. From your Joomla admin navigate to Extensions -> Extensions Manager -> Discover to install renamed template.
