1. carolyn
  4. Wednesday, 22 April 2015
I'd like to remove the article info ("Written by…";) underneath article titles. I found some custom code in another forum answer (article-info; display-none) that I added to the CSS section, but it doesn't work. I see in article options where publishing information can be displayed above, below, or split, but I'd like to have it not displayed at all. I'm working with the Stockholm template. Thanks.
Hi Carolyn
Would you have a URL to an example of your article?
To hide this information via CSS, try adding the following to the Custom CSS field of your templates parameters...
.createdby {
    display: none !important;
